PMarx.2
X-NUCLEO-NFC03A1 14443A emulation code
The example code for X-NUCLEO-NFC03A1 does not have a few methods mentioned in the headers, including st25r95SetACState(). This makes the 14443A emulation code not useful. Can you please provide the working example? Thank you
    Brian TIDAL
    Brian TIDALBest answer
    thanks for using ST25R95/CR95HF product. Card Emulation source code is not part of the X-CUBE-NFC3 v2.1.0 but I will provide it to you in private.
    Feel free to share more details about your card emulation application to help us to provide appropriate support.
    Rgds
    BT
    Brian TIDAL
    Rgds
    BT
    Hi BT,
    I also need the code for card emulation. Can you provide me with a copy of it?
