stj
Jun 2, 2014 1:00 PM UTC
Which reader IC for easy datatranfer to M24LR64E
Posted on June 02, 2014 at 15:00
in my last project I changed the eeprom to the M24LR64E.
Now I want
to creat
an
expansion
device with an reader Ic.
Which
ic
is the best/easyest for
the
data connection
of the two
devices
thank you and
greetings
from
Germany
#m24lr #reader
Anais GALLIGANI
Anais GALLIGANIBest answer
Jun 3, 2014 9:38 AM UTC
Posted on June 03, 2014 at 11:38
Hello Jochen,
You can use CR95HF transceivers, all information on www.st.com/nfc-rfid
(nfc/RFID transceivers tab)
You can have more information , a lot of AN , as such
- http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00266055.pdf
- http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00267228.pdf
I hope this is helping you,
Have a  nice day,
ST NFC/RFID Dynamic tag e2e support
Anais GALLIGANI
Hello Jochen,
Have a  nice day,
