Nir1
What is the RF tags i need to use in order to get from the ST25RU3993 5m range ?
    Marcel Rossignol
    Marcel RossignolBest answer
    you will need so-called far field tags to achieve a read range of 5m.
    These tags have usually a kind of loop in combination with a dipole.
    Here is a typical design example:
    The ST25RU3993 EVAL board demo kit includes two of such tags.
    Another important point is to have a far field reader antenna as well.
    The ST25RU3993 EVAL board demo kit does not include such a far field antenna!
    It just includes a near-field antenna (max. read range: 0.3m).
    So if you buy a ST25RU3993 EVAL board, you have to buy a far field reader antenna separately in order to achieve 5m read range.
    Best regards,
    Marcel
    Marcel Rossignol
    Best regards,
    Marcel
