Mpraj.19
what is problem when i write 0x01 at 0x0000 address of st25dv04k?
#include <stdio.h>
#include <sys/ioctl.h> // ioctl
#include <fcntl.h>    // open
#include <unistd.h>   // read/write usleep
#include <time.h>
#include <netinet/in.h> // htons
#include <linux/i2c-dev.h>
#include "smbus.h"
#define ADDRESS 0x53 // AT24C32's address on I2C bus
int main() {
 int fd;
 if ((fd = open("/dev/i2c-2", O_RDWR)) < 0) { printf("Couldn't open device! %d\n", fd); return 1; }
 if (ioctl(fd, I2C_SLAVE, ADDRESS) < 0)    { printf("Couldn't find device on address!\n"); return 1; }
write(fd,0x0000,0x01);
usleep(500);
 close(fd);
 return 0;
    Ronald B.
    Ronald B.Best answer
    Hello Mpraj.19,
    Please have a look to the STSW-ST25DV007 software package providing a Linux user space driver for the ST25DV-I2C, available here:
    https://www.st.com/content/st_com/en/products/embedded-software/st25-nfc-rfid-software/stsw-st25dv007.html#overview
    This software package comes with a User Manual for easy ramp-up.
    It must provide what you need to access ST25DV-I2C on a Linux platform.
    Ulysses HERNIOSUS
    would be good if you could share what you want to achieve as opposed what you observe....
    Above snippet looks a bit weird as the write() will probably try to read its 1 byte data from address NULL resulting in a fault.
    Regards, Ulysses
    Mpraj.19
    Mpraj.19Author
    I have to write 15 bytes in eeprom of tag ic ​
    Ulysses HERNIOSUS
    that is only first part answered - what you wan to do. Second is: What you observe. Does the program create log output? Please also feed back the return code of the write(call). What are your observations? And look again into the signature of the function - I think it is not used correctly.
    Regards, Ulysses
    Ronald B.
    Hello Mpraj.19,
    Ronald B.
    Hello Mpraj.19,
