Using the ST25RU3993 how do I request the EPC and a tags TID
- 4 replies
- 1167 views
I have distilled the example code provided for the ST25RU3993 evaluation kit down to issue a query, look for an RN, issue an ack and read the fifo on successful reception of the EPC number. I there a command other than the Query command that I can use to issue a request for the EPC and the TID number?
I have attached the code I have implemented so far for a bit of clarity.
