kinder228
Jul 9, 2013 8:51 AM UTC
Use the M24LR as an ''active tag''
Posted on July 09, 2013 at 10:51
I have a question about your M24LR products.
I know the product has been designed as a passive tag,
For RFID communication the power come from the reader and when we want to communicate via I2C we have to power the tag via 2 power pins (VCC and VSS).
My question is :  if I power the tag myself (via VCC and VSS) and then  try to communicate via RFID. Is it going to change the read range or not ? What energy source's the tag is going to use ?
I didn't see anything about that in the data-sheet. Do you have any idea if the range will be improved ?
Thank you
#read-range #m24lr-range-improve-power-tag #range-antenna-m24lr
Anais GALLIGANI
Anais GALLIGANIBest answer
Jul 17, 2013 8:43 AM UTC
Posted on July 17, 2013 at 10:43
Thanks for your interest in our product
If you power the tag, the read range might be a little improved (with high power reader, big antenna...)
And depending of the reader, you might not see a big difference.
And like  you power the tag, the digital part will be powered earlier.
I hope this might help you,
Best Regards,
Have a nice day,
Dynamic NFC/RFID tags support
Anais GALLIGANI
Best Regards,
Have a nice day,
