NASOK.1
Trying to detect the NFC tap
I am trying to detect the NFC tap and try to raise a flag whenever a flag is seen and to do the same function each time.is there any example available?I am able to read and write to EEPROM but I don't get any idea how to detect a tap
Berenice BENVEGUDA
Hi @NASOK.1 ,
Please have a look at GPO feature in ST25DV datasheet available there : https://www.st.com/en/nfc/st25dv64kc.html
the RF_ACTIVITY or FIELD_CHANGE mode can help you to fit with your needs. at a tap you will be able to get a flag on GPO output.
I hope this helps,
Best Regards,
BB
Berenice BENVEGUDA
Hi @NASOK.1 ,
I hope this helps,
Best Regards,
BB
