FZhao
Jun 21, 2019 10:47 AM UTC
through ST25DV to communicate with I2C Sensor
I am thinking if it is possible to connect a low power I2C sensor to ST25DC, and use a reader to read out the values through the ST25DV(Powered by the Veh from ST25DC), or do I need extra MCU between the ST25DV and the I2C sensor to done the communication?
JL. Lebon
JL. LebonBest answer
Jun 24, 2019 7:44 AM UTC
​Hello,
The ST25DV-I2C is I2C slave device only. In order to read data in your sensors, you need a master device, so you will need to add an MCU. The MCU will be I2C master for both sensors and ST25DV.
Best regards,
JL. Lebon
​Hello,
Best regards,
