PVerm.3
STUHFL demo code with debian linux: only empty tags
Using ST25RU3993 RFID with Rpi 4 and it work fine with STUHFL demo code. with debian linux Arm Cortex-A9, Is it compatible as I am getting only empty tags. please guide me.
    Nick K
    Nick KBest answer
    as the STUHFL middleware and demo code is written in ANSI C it should work also on Cortex-A9 if compiled with a proper compiler/toolchain.
    If no TAGs are found please check your HW setup and check if tuning is correct applied to the carrier cancelation circuit.
    Another common issue is a version mismatch between the board FW and the STUHFL middleware.
    BR
    Nick K
    Nick KBest answer
    BR
