angad
May 31, 2019 3:11 AM UTC
STSW-ST25R001 GUI Is not installing
When I try to install the GUI ,windows says this: "This app can't run on your PC".
How does one get the GUI up and running? Please advise.
    Ulysses HERNIOSUS
    Jun 7, 2019 9:04 AM UTC
    Hi Angad,
    In the meantime the CMS got changed. I was able to correctly download as zip now. Please check.
    If just the error message would be more helpful:
    This app can't run on your PC.
    To find a version for your PC, check with the software publisher.
    doesn't really help to figure out that it's just a wrong suffix. I think this is still an heritage from MSDOS and Win10 made it worse with its new error message.
    Regards, Ulysses
    Brian TIDAL
    May 31, 2019 2:01 PM UTC
    which version of Windows is installed on your PC?
    Rgds
    BT
    angad
    angadAuthor
    May 31, 2019 2:13 PM UTC
    Windows 10 Home
    Version 1803
    Ulysses HERNIOSUS
    Jun 6, 2019 12:27 PM UTC
    the message you got is most likely due to the fact that we have moved from .exe content on the web to .zip content on the web. Unfortunately during a short window there was a .exe with zip content which produces this weird/misleading message.
    Please try again to download.
    Regards, Ulysses
    angad
    angadAuthor
    Jun 6, 2019 4:31 PM UTC
    I downloaded the file again. But the problem still persists. Same error as before
    Kindly advise
    Best,
    Angad
    Ulysses HERNIOSUS
    Jun 7, 2019 6:20 AM UTC
    Hi Angad,
    the issue should have been fixed several days ago but still persists. Probably the right incantations for our CMS need to be executed...
    For now: Download and change the suffix to .zip manually. Sorry for the inconvenience!
    Regards, Ulysses
    Ulysses HERNIOSUS
    Hi Angad,
    Regards, Ulysses
