embedsol
STM32F0 eeprom issue
Posted on May 19, 2016 at 12:58
hello
i am using stm32f03 to interface with eeprom but i am unable to read data please provide help on this
my code is attatched
void I2C_WrReg(uint8_t Reg, uint8_t Dat)
while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_BUSY) == SET);
I2C_TransferHandling(EEPROM_I2C, EEPROM_ADDRESS_RD, 1, I2C_Reload_Mode, I2C_Generate_Start_Write);
while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_TXIS) == RESET);
I2C_SendData(EEPROM_I2C, Reg);
while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_TCR) == RESET);
I2C_TransferHandling(EEPROM_I2C, EEPROM_ADDRESS_RD, 1, I2C_AutoEnd_Mode, I2C_No_StartStop);
I2C_SendData(EEPROM_I2C, Dat);
while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_STOPF) == RESET);
I2C_ClearFlag(EEPROM_I2C, I2C_FLAG_STOPF);
uint8_t I2C_RdReg(uint8_t Reg)
uint8_t Dat;
I2C_TransferHandling(EEPROM_I2C, EEPROM_ADDRESS_RD, 1, I2C_SoftEnd_Mode, I2C_Generate_Start_Write);
while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_TC) == RESET);
I2C_TransferHandling(EEPROM_I2C, EEPROM_ADDRESS_RD, 1, I2C_AutoEnd_Mode, I2C_Generate_Start_Read);
while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_RXNE) == RESET);
Dat = I2C_ReceiveData(EEPROM_I2C);
return Dat;
A0 is write address
A1 is read address
Rene Lenerve
Rene LenerveBest answer
Posted on May 27, 2016 at 13:50
Hello qasim,
What do you mean by A0 is write address, A1 is read address?
For the M24LR, device address is A6 for data area write (A7 for read) and AE to write config register (AF to read), you can refer to the datasheet of the M24LR for that.
http://www.st.com/content/st_com/en/products/memories/nfc-rfid-memories-and-transceivers/dynamic-nfc-rfid-tags/m24lr-series/m24lr04e-r.html
Hope this will help you.
Kind Regards.
Rene Lenerve
Hello qasim,
Kind Regards.
