Visitor
STEVAL-25R200SA – Multi-Antenna Support, Reading Range, and NDEF Compatibility
Hi everyone,
I'm evaluating the STEVAL-25R200SA (ST25R200) for an autonomous NFC reader system. The goal is to read NFC Type 2 (NTAG213/215/216), Type 4 (NTAG424 DNA), and Type 5 (ST25TV02KC) tags, including their NDEF UTF-8 text messages.
The tags will be attached to a 6 × 6 × 6-inch cube and may be located anywhere on one of its five exposed faces.
I reviewed the kit's documentation and saw that it supports two independent antennas. I also found AN6121, which demonstrates a six-antenna multiplexing approach.
I have a few questions:
  1. Multiple antennas: Can the approach in AN6121 be implemented with the STEVAL-25R200SA to support four or five external antennas? What hardware modifications would be required?
  2. Reading range: Are there measured reading distances for the Type 2, 4, and 5 tags listed above using the kit's antennas? I'm particularly interested in reliable NDEF message retrieval rather than just tag detection.
  3. Custom antennas: Would larger antennas improve coverage across a 6-inch cube face? Are there recommended antenna sizes, cable lengths, or tuning considerations?
  4. Software: Does the available firmware support NDEF UTF-8 text decoding for all three tag types, and can it be integrated with a Raspberry Pi or Jetson running Linux?
Any recommendations, reference designs, or documentation would be appreciated. Thanks!
