ST25R3916B Programming with nucleo board STM32F429
I have NFC08 Card Reader and Nucleo Board STM32F429. I know X-CUBE-NFC6 Sotfware expansion develop  NUCLEO-L053R8 or NUCLEO-L476RG board. How to programming ST25R3916B with Board nucleo F429?
Do Library, Middleware... of X-cube NFC6 suitable with Nucleo Board STM32F429?
Thanks your help!
Brian TIDAL
Brian TIDALBest answer
STM32CubeMX supports X-CUBE-NFC6 since version 3.0.0 of this package. This means that you can use SM32CubeMX to generate NFC applications with any NUCLEO board such as STM32F429. Inside the Documentation folder of the package, you will find a getting started PDF that details the various steps to configure the MCU and to generate the NFC application.
Rgds
BT
Brian TIDAL
Rgds
BT
mystar411Author
Thank for your help! How about X-CUBE-NFC5? May I using ST25R3911B with any NUCLEO board with X-CUBE-NFC5?
Brian TIDAL
STM32CubeMX supports X-CUBE-NFC6, X-CUBE-NFC9 and X-CUBE_NFC10 packs.
X-CUBE-NFC5 and X-CUBE-NFC3 are not integrated into STM32CubeMX. It is possible to use then with any NUCLEO but this requires more manual effort. Some posts on this community explain how to port X-CUBE-NFC5/3 on any NUCLEO board.
Rgds
BT
