philipweiss
Oct 31, 2017 6:51 PM UTC
st25r3911b transparent mode example
Posted on October 31, 2017 at 19:51
Is there any sample code to put the ST25R3911B into transparent mode?  I have been unable to make the
ST25R3911B output OOK in transparent mode.
I need this functionality because I'm implementing a proprietary protocol.
My configuration/use model:
  • My circuit uses MCU_CLK as required for timing
  • I configure the ST25R3911_REG_OP_CONTROL register to enable TX and disable RX
  • I clear ST25R3911_REG_AUX_tr_am and set ST25R3911_REG_AUX_ook_hr in the ST25R3911_REG_AUX register to enable OOK.
  • I execute the 0xDC command (ST25R3911_CMD_TRANSPARENT_MODE) to enable transparent mode.
  • I configure the MOSI pin to push-pull output
  • I expect changes to MOSI to be reflected when I measure from RFO1 to RFO2, with an oscillating signal (MOSI high), or nothing (MOSI low).
But, unfortunately, I don't get any signal on RFO1/RFO2.
Any assistance would be greatly appreciated.
    Ulysses HERNIOSUS
    Dec 14, 2017 2:28 PM UTC
    Posted on December 14, 2017 at 15:28
    unfortunately ST does not have support code showing usage of transparent mode on ST25R3911B.
    Looking through your procedure looks reasonable. Some paths to look into:
    • You don't mention oscillator enabling 'en' bit: I assume you did that. Not getting any signal might sound like this.
    • ook_hr should not be needed, I am not exactly aware what happens if ==1
    • Please observe that /SS line is not going low again after the Enter Tansparent Mode command.
    Regards, Ulysses
    Ulysses HERNIOSUS
    Regards, Ulysses
    philipweiss
    Dec 19, 2017 12:35 AM UTC
    Posted on December 19, 2017 at 01:35
    I'm sorry to hear that ST does not have any support for transparent mode.  I have been, however, able to make some changes to the code to make both transmit and receive work in transparent mode.
    Thanks for your help.
