vaibh_p
ST25R3911B SPI Check
Hi ,
After starting power supply , without any configuration od ST25R3911B, can we directly read the "IC Identity Register 0x3F" just to check the SPI with the controller is working or not ? Will it give the value specified in the datasheet or should I have to do some configurations before reading that?
    Ulysses HERNIOSUS
    yes IC identity register value will appear immediately at startup, no additional oscillator startup or anything needed.
    Regards, Ulysses
    dbgarasiya
    Senior
    how can you say that it is possible ?
    vaibh_p
    vaibh_pAuthor
    I just want to check my SPI is working or not, writing to any register may cause some problem so I just want to read any register.
    Ulysses HERNIOSUS
    Regards, Ulysses
