roy23
Aug 25, 2022 6:45 AM UTC
ST25R3911B read range
I have bought ST25R3911B-Disco board for proof of concept.
I need to be able to read the tag for identification from ~50 cm.
currently I have ST25TA tag and it I can read it from ~3cm.
 I understand I need to buy tag ST25TV with NFC type 5.
can you guide me how I get the ST25R3911B-Disco to work in long ranges ?
what kind tag I need to buy ?
will I need to change the setting in the registers map to get long ranges ?
will the disco be able to provide long range readings ?
if not what reader/eval board can do the job?
Brian TIDAL
Brian TIDALBest answer
Aug 26, 2022 8:17 AM UTC
For similar questions about how to increase the read distance on ST25R3911B, see:
For your prototyping and tests, you can find ST25TV tags in :
Note that the ST25R3916 or ST25R3916B reader can also be used for application requiring an important reading distance.
Rgds
BT
Brian TIDAL
Rgds
BT
