VMana.1
ST25R3911B / NFC reader / No-response timer register
I would like to increase no-response time by a few ms instead of 64/fc (4.72us) or 4096/fc(302.08us?), say 100ms(milliseconds). What should be the values in 0Fh, 10h and 11h registers.? I see bit4 in 0Fh register mentions time configuration in milliseconds configuration but don't how to use.
Host uses rfal API.
Thank you for your support!
Thanks,
Veera
    Brian TIDAL
    Brian TIDALBest answer
    the rfalTransceiveBlockingTxRx() and rfalTransceiveBlockingTx() APIs in the RFAL have a fwt parameter (Frame Waiting Time in 1/fc). This will set the No-response timer registers accordingly.
    Can you elaborate about your use case (e.g. which technology A/B/F/V/P2P) and explain why you need to increase the non response timer?
    Rgds
    BT
    Brian TIDAL
    Rgds
    BT
    VMana.1
    VMana.1Author
    Sorry I missed your response somehow I did not receive a notification though.
    We've an application level security added and ran into some issues at the RF transport. To debug, I want to try to extend the non-response timer to a few milli seconds. We sorted out the issue. Thank you for your support.
    Thanks,
    Veera
