ST25R3911B Fast Transfer Mode
- 4 replies
- 1271 views
Hi!
I am part of a research project which utilizes the X-NUCLEO-NFC05A1 and ST25R3911B-DISCO boards, as well as ST25DV04K chip, for exploring Fast Transfer Mode (FTM) and I am in urgent need for your help in order to being able to proceed. Unfortunately, neither was I able to find documentation about FTM and its respective SPI commands at the reader side, nor could I find anything about FTM in the STSW-ST25R002 sources. Nevertheless, in the ST25R3911B Discovery GUI, provided in STSW-ST25R001, FTM is implemented and it is working as intended. Even the search for the respective command codes for FTM Read Message Length (0xAB) and FTM Read Message (0xAC) ended in no results whatsoever.
I hope you can help me out and thanks in advance!
