ST25R3911B does not work with ST25DV16KC
we use the ST25DV16KC and for development i use the ST25R3911B.
Problem is:
ST25R3911B connected via micro usb to the pc.
so far looks good
Pressing the TAG Editor Button
I just want to read the config:
Pressing Button Read Configuration leads to this:
Same board same chip on my colleagues desk works.
1: What could be the issue?
2: Is there an alternative reader? Suggestion for scripting?
Kind Regards
Damien G.Best answer
The Tag Editor from the ST25R3911B-DISCO GUI is based on the CR95HF development software.
This software is no longer maintained and does not support ST25DVxxKC products.
@tunguskar , the crash from the ST25PC-NFC software is caused by missing older MSVC DLLs on newer Windows environment and was thought to be resolved in the recent versions.
If this is not the case, lease download and install the Visual C++ Redistributable Packages for Visual Studio 2013
https://www.microsoft.com/en-us/download/details.aspx?id=40784
Best regards,
Damien
Ulysses HERNIOSUS
Hi tunguskar,
the ST25 tag editor provided with ST25R3911B-DISCO GUI is to my knowledge not supporting the latest ST25DV*KC evolution of the products. Might be related to that, but not sure.
Not sure about your result at your colleague. You say everything the same (ST25DV tag, ST25R3911B board, ST25R3911B-DISCO GUI and ST25 Tag editor) - but result is different?
BR, Ulysses
tunguskarAuthor
Result is that at leas at my colleagues desk reading is possible. Even though the gui is not compatible with the chip. What else tooling can i use for this NFC chip?
Ulysses HERNIOSUS
STSW-ST25PC001 should fully support ST25DV64KC. I didn't verify but it should also support the ST25R3911B-DISCO board as reader.
BR, Ulysses
tunguskarAuthor
Hi Ulysses,
I installed the software, unfortunately it crashes immediately after start. I see a short pop up of the software and than crashes. No report, or where can I find the report normally?
I have windows 11 running version 24H2
Ulysses HERNIOSUS
works on my side. Maybe @Damien G. can give some hints.
BR, Ulysses
Best regards,
Damien
tunguskarAuthor
Thanks for the hint, unfortunately this solved not the problem. But I did no reboot until now, maybe afterwards?
Kind regards
Berenice BENVEGUDA
Hello @tunguskar ,
Did the reboot solve your issues ?
Best Regards,
BB
