RFlod.2
Senior
ST25R3911 Capacitance measurement
I have RFID reading with ST25R3911 working now with RFAL and  I would like to sense if there is a RFID tag nearby before starting RFID reading.
I did not find any example code in RFAL. I looked into data sheet and tried to read the registers:
st25r3911ReadRegister(0x3C, &c);
printf("CapA %d\n\r", c);
st25r3911ReadRegister(0x3D, &c);
printf("Cap %d\n\r", c);
st25r3911ReadRegister(0x2B, &c);
printf("Volt %d\n\r", c);
but I just get zeros:
CapA 0
Cap 0
Volt 176
How shall this be done?
Ulysses HERNIOSUS
Hi RFlod.2,
yes. But as said I strongly recommend to start from ST25R3911B-DISCO board. It will be working out of the box.
We have looked into the X-NUCLEO-NFC05 and have not found any obvious reason for it to to not work.
Regards, Ulysses
Ulysses HERNIOSUS
Capacitance measurement is a feature of the Wake-up system. Best if you get the ST25R3911B-DISCO whose GUI has a tab for experimenting with it. Also the related AN4985 will give some explanation.
From RFAL perspective you have the following entries:
  • st25r3911MeasureCapacitance()
  • st25r3911CalibrateCapacitiveSensor()
  • rfalWakeUpConfig.cap
Please beware that this feature will also react to water/human body and is more susceptible to emission from other radios / fluorescent lamps, etc. than the inductive wake-up system.
BR, Ulysses
RFlod.2
RFlod.2Author
Senior
I tries the functions and they seem to work. But I get very small changes (on ST devkit) like :
No card: 140
One card:  137
Another card:142
When using
st25r3911MeasureCapacitance(&c);
Is this expected?
Ulysses HERNIOSUS
which devkit are you using?
BR, Ulysses
