Stasevich
ST25R39 (Reading next to metall surface )
Is there any way to get an antenna working in reader mode (chip 3911) when placed very close to a metal surface (around 2–3 mm)?
I did some experiments with NFC in modern smartphones — their antennas sit right on top of the battery surface, and everything works fine there. But when I tried the same idea with the 3911 and 3916 evaluation kits, the antennas turned out to be pretty much ineffective.
Ulysses HERNIOSUS
typically you would be using a ferrite. https://www.st.com/content/st_com/en/support/learning/essentials-and-insights/connectivity/nfc/nfc-touchpoints.html could be a start for your investigation here.
BR, Ulysses
AScha.3
What metal ? magnetic (steel) or not (copper, Lithium...as the battery is) ? with high loss or low impedance?
This might be the important point, try non magnetic and an LiPo near the antenna .
Also size and shape of the conductive area rel. to the antenna form and size is important,
to modify the 3-D form the field gets as result , not just being an absorber for the field.
Just think on the RF antennas, small difference in size makes a reflector or a director for a certain frequency:
...and the optimum distance to get the desired effect.
Ulysses HERNIOSUS
BR, Ulysses
