WGorm.1
Sep 21, 2022 12:02 PM UTC
ST25R reader for MB89R118C tag
Which ST25R reader would you recommend for the MB89R118C Fujitsu Tag which has FRAM of 256 memory blocks/ 2048 bytes and uses ISO/IEC15693? For some reasons I could not write or read from this NFC type 5 tag with the NFC Tap app? Please advise.
    Brian TIDAL
    Brian TIDALBest answer
    Sep 21, 2022 12:11 PM UTC
    MB89R118C is a 8-byte per block device. This can be read by any of the ST25R device (ST25R95, ST25R3911B or ST25R3916/3916B).
    In ISO/IEC15693 mode, NFC Tap app is limited to 4-byte per block device thus MB89R118C cannot be read by this app.
    Rgds
    BT
    Brian TIDAL
    Rgds
    BT
    WGorm.1
    WGorm.1Author
    Sep 21, 2022 12:16 PM UTC
    Thank you so much! Would you recommend another app that may do 8-byte per block if any?
    Brian TIDAL
    Sep 21, 2022 12:27 PM UTC
    Well, difficult for me to recommend an app from the competition ;) but if you google "app NFC Tag Info", you should find some apps.
    Rgds
    BT
