Dan S_2
ST25DV04KC fails EN300330 due to 2nd harmonic level exceeded limit
Hi
I am using ST25DV04KC tag in my product. During EN300330 test, there is a very high 2nd harmonic component radiated and exceeds the limit when the NFC reader is placed beside the tag. Anyone encounter this issue before?
For Type-5 tag, is it normal to see a high 2nd harmonic component during communication with the reader?
Thanks.
Rgds
Dan
Jacob WOODRUFFBest answer
Hi All,
This question has been routed to our online support center for direct assistance.
Regards,
Jake
ST Support
Dave D
It is difficult to comment because each configuration is different, however I can share some of the observations we did when certifying our boards.
We saw that changing the power supply and/or the usb cable to power the board can impact the results. Also we saw that the reader used for the test, can have an impact. We have used the ST25R3911B-Disco board as a reader and it was working fine.
Hi All,
Regards,
Jake
ST Support
