ST25DV
I am using ST25DV chip as NFC RF chip, can X-NUCLEO-NFC07A1 have an external antenna?Can ANT7-T-25DV64KC have an external antenna? Is there any other can external antenna?
Alan BSTBest answer
Neither ANT7-T-25DV64KC nor X-NUCLEO-NFC07A1 have the possibility to disconnect the antenna to connect an external antenna in place. However, it's possible to cut the antenna track and solder an external antenna on it, up to you.
Thanks,
Alan BSTBest answer
Thanks,
