ST25 NFC/RFID tags enstsw-95hf002
After downloading the enstsw-95hf002 code example, I try to compile the project
and getting these errors
Brian TIDAL
Brian TIDALBest answer
This is linker errors: the symbols from the CR95HF.DLL are not found. Make sure to have the CR95HF.lib  DLL import lib in the linker command. Also, make sure to includeCR95HFDLL.h in your sources using the DLL APIs.
Rgds
BT
Brian TIDAL
Rgds
BT
