michael23
Jul 30, 2013 2:09 PM UTC
ST demo M24LRxx_Application Software (Demo Kit USB based), reader application differences
Posted on July 30, 2013 at 16:09
Hello
I try to find out the difference between Reader Application M24LR04E and Reader Application M24LR16E when it comes to data reading.
As far as I understood both components (M24LR04E and M24LR16E) operate with identic commands.
In my case I only want to read data from block 0x000 to 0x00F. On both components exist the requested memory range. Further I do not use any password protection.
When I read data from M24LR16E with Reader Application M24LR04E all what I get back is just ''no Tag answer''.
Why only M24LR16E works with Reader Application M24LR16E and not with Reader Application M24LR04E? Where is the difference?
Anais GALLIGANI
Anais GALLIGANIBest answer
Aug 1, 2013 3:38 PM UTC
Posted on August 01, 2013 at 17:38
Concening the adress for different density devices, might you tell me if the following AN help you ??
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00048677.pdf
Both M24LR04E & M24LR16E shall work with DEMOKIT-M24LR-A (is it the kit you are using?)
Are you using them in addressed mode?
 Thanks a lot,
Have a nice day,
All the best,
ST dynamic NFC/RFID tag support
P.S : Concerning protection mechanism , please  see AN 3002 http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00239158.pdf
More AN on
http://www.st.com/nfc-rfid
Anais GALLIGANI
 Thanks a lot,
Have a nice day,
All the best,
More AN on
