JLiew.1162
RFID reader for STEVAL-SMARTAG1
I am curious if there is a RFID reader that extends the communication distance for STEVAL-SMARTAG1. If so, could you kindly provide the link and description.
Thanks in advance,
J.X
    Berenice BENVEGUDA
    ​Hello,
    First of all, thanks for your interest in ST smartag product !
     If the communication distance reached with ST NFC HF readers is not sufficient for your application you can have a look  at FEIG readers such as LR1002 for example
    Hope this helps,
    Best Regards,
    BB
    Berenice BENVEGUDA
    ​Hello,
    Hope this helps,
    Best Regards,
    BB
    JSant.5
    Dear, I have got in touch with FEIG and they told me that none of their products can handle the STEVAL-SMARTAG1 protocol. Could you please recommend another company? see below the message from FEIG.Good afternoon,
    Thanks for your request and we a the distributor of FEIG Electronic will inform you.
    I looked at the specifications of this tag and this one does not support the protocols the FEIG readers support. The FEIG readers support ISO14443, ISO15693 (HF) and GEN 2 (UHF) so in this case they are not able to read the tag.
    Met vriendelijke groeten, Best regards,
    Arnold Zweep
    Inside sales
    Duranmatic B.V. - Auto-ID
    +31 (0)78 65 31 872 - auto-id@duranmatic.nl
    Ulysses HERNIOSUS
    Hi JSant.5,
    I can only imagine a misunderstanding here:
    STEVAL-SMARTAG1 uses ST25DV. ST25DV is an ISO15693/NFC-V tag so supported by the Feig reader.
    Regards, Ulysses
    JSant.5
    Dear Ulysses,
    OK many thanks for the information, I will then contact them again, probably indeed there was a misunderstanding.
    Regards,
    Juan
