Travis Palmer
Travis PalmerBest answer
Hello Peter,
This calculation is only required if your device is operated within a certain distance of an human body.
At the time we did the certification of the ST25R3911B-DISCO it was around 20cm.
Since the ST25R3911B-DISCO is not intended to be operated in close proximity to the human body, those calculations where not be required.
I assume such calculation is more for devices like implants or device which are in close proximity to the human body.
The below link should help you proceeding with your calculation.
https://apps.fcc.gov/kdb/GetAttachment.html?id=f8IQgJxTTL5y0oRi0cpAuA%3D%3D&desc=447498%20D01%20General%20RF%20Exposure%20Guidance%20v06&tracking_number=20676
If you have any doubt I would recommend you to crosscheck with the accredited lab, which carries out your compliance measurements.
BR Travis
Ulysses HERNIOSUS
Hi PeterSPX,
did you check https://fccid.io/YCPR3916DB1 ?
Best Regards, Ulysses
PeterSPX
PeterSPXAuthor
Yes, but there is no information about der RF Power conducted.
Travis Palmer
Hello Peter,
could you please detail a bit where you need to fill this parameter and to which part of the FCC standard it is related?
Is it for defining the Equipment class?
Many Thanks, BR Travis
PeterSPX
PeterSPXAuthor
PeterSPX
PeterSPXAuthor
This is the FCC Part:
Radio frequency devices operating under the provisions of this part are subject to the radio frequency radiation exposure requirements specified in §§ 1.1307(b), 1.1310, 2.1091, and 2.1093 of this chapter, as appropriate. Applications for equipment authorization of RF sources under this section must contain a statement confirming compliance with these requirements. Technical information showing the basis for this statement must be submitted to the Commission upon request.
Travis Palmer
Hello Peter,
BR Travis
