Request for PCB Source Files of the Reference Design in AN5592 Figure 6
Hello ST Team,
I am currently working on a project using the ST25R3916B NFC reader, and I would like to study and reference the PCB design shown in Figure 6, “Device used for single ended antenna with cable,” of application note AN5592.
Could you please provide the editable PCB project files for this reference design, such as the Altium schematic and PCB layout files?
I have checked the application note and the ST website, but I could not find the corresponding PCB source files.
Application note reference:
https://www.st.com/resource/en/application_note/an5592-st25r-single-ended-antenna-matching-stmicroelectronics.pdf
Thank you very much for your support!
Travis Palmer
Travis PalmerBest answer
Hello StarryLiu,
The reader PCB is a modified NFC08A1 PCB. The antenna has been removed and an SMA connector soldered.
No other then the official available NFC08A1 gerber files exists.
The antenna was derived from the ST25R3916B eval board. I can send you the gerber files via PM.
Please let me know, if you have further questions.
BR Travis
Travis Palmer
Hello StarryLiu,
BR Travis
