emil28
Read Mifare Ultralight ST25R3911
I am using ST25R3911 to read ISO15693 tags with the ST example from X-CUBE-NFC5. Everything works fine, now, I would like to read memory of Mifare Ultralight (without encryption). I know that st25 can't read Classic Mifare, but I don't find the code in the library to read blocks of Mifare Ultralight (ISO 14443). Does it exist ?
Thanks.
    Ulysses HERNIOSUS
    you will need to add yourself the proper calls to rfalT2TPollerRead(). Out of the box it tries to read on a T2T the Capability Container according to NFC Forum T2T specification and based on its content tries to read the NDEF area.
    Regards, Ulysses
    Ulysses HERNIOSUS
    Mifare Ultralight follows NFC Forum T2T specification and can be formatted as a T2T (using e.g. the Manufacturers Android App). When formatted its content can be read using X-CUBE-NFC5 v2.0 (PollingTagDetectNDEF).
    The low level access functions are implemented in rfal_t2t.c.
    Regards, Ulysses
    emil28
    emil28Author
    Thanks for your quick answer.
    Is it possible to read the tag out of box with X-CUBE-NFC5, but without formatted the tag as a T2T ?
    Thanks.
    Ulysses HERNIOSUS
    Regards, Ulysses
