MCanf.1
read memory of ST25DV64K-I using android studio
I want create one app that with NFC read the memory of ST25DV64K-I.
i try the official app ST25 and read the memory... but using the st25sdk-1.10.0 libraries.
i use android studio.i can read the Tag name and UID, but i can't find how to read the memory
France Berthelot
France BerthelotBest answer
Hello
With our application you can read memory.
Feature used is : when tag has been tapped, you use Memory content feature/menu to R/W/Dump memory
Source code is available here: https://www.st.com/en/embedded-software/stsw-st25001.html
Here an extract from the source code as example using our SDK and for different Tag type
Assuming : NFCTag mTag;
if (UIHelper.isAType4Tag(mTag)) {
   // Tag type 4
   int size = getMemoryAreaSizeInBytes(((Type4Tag) mTag), mArea);
   mNumberOfBytes = size;
   mStartAddress = 0;
   int fileId = UIHelper.getType4FileIdFromArea(mArea);
   // inform user that a read will be performed
   snackBarUiThread();
   if (mReadPassword != null && mTag instanceof STType4Tag) {
       mBuffer = ((STType4Tag) mTag).readBytes(fileId, 0, size, mReadPassword);
   } else {
       mBuffer = ((Type4Tag) mTag).readBytes(fileId, 0, size);
   mReadPassword = null;
   int nbrOfBytesRead = 0;
   if (mBuffer != null) {
       nbrOfBytesRead = mBuffer.length;
   if (nbrOfBytesRead != mNumberOfBytes) {
       showToast(R.string.error_during_read_operation, nbrOfBytesRead);
} else if (UIHelper.isAType5Tag(mTag)){
   if (mArea == -1) {
       mAreaId = getAreaIdFromAddressInBytesForType5Tag(mStartAddress);
   if (mAreaId == -1) {
       // An issue occured retrieving AreaId from Address
       // Address is probably invalid
       showToast(R.string.invalid_value);
       return false;
   } else {
       // Type 5
       mBuffer = getTag().readBytes(mStartAddress, mNumberOfBytes);
       // Warning: readBytes() may return less bytes than requested
} else if (UIHelper.isAType2Tag(mTag)){
   if (mArea == -1) {
       mAreaId = getAreaIdFromAddressInBytesForType2Tag(mStartAddress);
       return false;
   } else {
Search file : ReadFragmentActivity in source code, and you will found way of doing memory read.
For write refers to WriteFragmentActivity
Rgds,FB
France Berthelot
Hello
   // Tag type 4
   mStartAddress = 0;
   snackBarUiThread();
   } else {
   if (mArea == -1) {
       return false;
   } else {
       // Type 5
   if (mArea == -1) {
       return false;
   } else {
Rgds,FB
