Problem rw on ST25TV02KC ISO15693
- 2 replies
- 1632 views
I'm using a DLP-RID2 device to write and read data in a ISO 15693 TAG, in particular i'm using tags based on the ST25TV02KC which have 320 bytes of information arranged in 80 blocks of 4 bytes each.
My problem is that with a new factory TAG, i can't read block 50, and read/write operations don't works.
Do you have any suggestions for any commands to use to be able to use all 80 blocks?
I attach a log that illustrates the commands sent for a read
Best regards
