Bassem
May 2, 2026 17:45 UTC
NUCLEO-C071RB Example with X-NUCLEO-NFC12A1 not working
Dear ST colleagues,
I tried recently the package X-CUBE-NFC12.
First I tested on NUCLEO-L476RG board the delivered example and it was working out of the box, then I tried on NUCLEO-C071RB but it was not working, first I noticed that the Pins configuration are not correct it was fixed, but still not working, did anyone ever test this example, because I assume it needs to work without any modification.
Thank you in advance for your support.
Best regards
Bassem Taamallah
Brian TIDAL
Brian TIDALBest answer
May 4, 2026 21:40 UTC
I guess this is due to the polarity of the user button on NUCLEO-C071RB vs. NUCLEO-L476RG (active high vs. active low)
See https://community.st.com/t5/st25-nfc-rfid-tags-and-readers/integrate-nfc08a1-expansion-board-with-stm32-u575zi-q/td-p/745862
Rgds
BT
Brian TIDAL
Rgds
BT
