Schuyler
NFC07A1 antenna design
Do you have the antenna size and design process reference of NFC07A1? I want to know how to match the circuit and what is the inductance of the antenna.
    JDEME
    JDEMEBest answer
    The inductance should be around 5.4µF (for some designs around 4.7µH for the ST25DV)
    Regards,
    JDEME
    I the DB you can find the size (54 mm diameter). [Documentation]
    The Gerber is also available, [cad-resources]
     The main link: X-NUCLEO-NFC07A1 - Dynamic NFC/RFID tag IC expansion board based on ST25DV64KC for STM32 Nucleo - STMicroelectronics
    Useful link for antennas:
    How to design a 13.56 MHz customized antenna for ST25 NFC / RFID Tags - Application note
    Schuyler
    SchuylerAuthor
    Hi @JDEME
    I've seen the size of the antenna, but I haven't found out what is the inductance L of this antenna? The manual only shows the antenna of the ST25T series, so what is the inductance of the ST25DV antenna?
    JDEME
    JDEMEBest answer
    Regards,
