KKulk.1
NFC card reader for ST25DV16KC tag
I'm working with the ST25DV16KC-IE6T3 tag (ISO15693 type 5) and I want to both read and write data to it.
I'm looking for a compatible NFC card reader that can connect to the computer via USB port (either desktop PC or laptop.)
The use case would be to write an application in LabVIEW that can use this reader to read/write data to the above-mentioned NFC tag in hex format.
Maybe someone can help me with the following questions:
1 - Can anyone recommend a NFC reader that can communicate with NFC type 5 tags?
2 - Can anyone recommend a LabVIEW library for communicating with NFC type 5 tags?
Thanks!
Joe WILLIAMS
Joe WILLIAMSBest answer
Hi KKulk.1
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Kind Regards
Joe WILLIAMS
STMicro Support
Brian TIDAL
All ST25R reader devices support ISO15693/NFC Type 5 tags.
Evaluation or Discovery boards for ST25R3916/ST25R3916B or ST25R3911B (STEVAL-25R3916B, ST25R3916-DISCO or ST25R3911B-DISCO) can be connected to a PC over USB. A communication DLL is available (e.g. ST25R3911DISCOComm.dll). I am not aware of a LabView interface library but some users (@John63)  have developed their own solution based on this communication DLL. See https://community.st.com/t5/st25-nfc-rfid-tags-and-readers/st25r3911b-disco/m-p/627283.
Rgds
BT
Joe WILLIAMS
Hi KKulk.1
Kind Regards
Joe WILLIAMS
STMicro Support
