David.Cheng
Jul 22, 2019 8:00 AM UTC
NFC as wireless EEPROM memory
HELLO ALL! i want to do point to point (P2P) data exchange between the NFC and a smart phone,
Im new to NFC, require 64Kbyte EEPROM and mcu can write it, how to choose the chip
    Brian TIDAL
    Brian TIDALBest answer
    Jul 23, 2019 8:10 AM UTC
    See our various demos with dynamic tags:
    Getting Started NFC: ST25DV discovery kit smartphone demo
    Getting Started NFC: ST25DV discovery kit demonstration using ST25R3911B reader
    if you want to prototype an application based on dynamics tags, you can use the following Discovery kits:
    • ST25DV-DISCOVERY Discovery kit for ST25DV04 Dynamic NFC/RFID tag IC with fast transfer mode capability
    • M24LR-DISCOVERY Discovery kit for CR95HF Reader & M24LR04E Dynamic NFC / RFID Tags with energy harvesting
    • M24SR-DISCOVERY Discovery kit for the M24SR series - Dynamic NFC/RFID tag
    Rgds
    BT
    Brian TIDAL
    Jul 22, 2019 1:23 PM UTC
    if my understanding is correct, you would like something like this:
    MCU <---Local Interface---> Tag <--- RF interface ---> Smartphone
    i.e. a tag with an NFC interface (communication with a smartphone) and with a local interface for communication with an MCU
    In such case, you can use the following products
    • ST25DV64K if you want ISO/IEC 15693 products (Long Range) supporting a Fast Transfer Mode through a Half-duplex 256-byte dedicated buffer
    • M24LR64E-R if you want ISO/IEC 15693 products (Long Range)
    • M24SR64-Y if you want ISO/IEC 14443 products (Short Range)
    Those products can be operated from an I2C interface or by a 13.56 MHz RFID reader or an NFC phone. The I2C interface uses a two-wire serial interface, consisting of a bidirectional data line and a clock line. It behaves as a slave in the I2C protocol.
    See ST25 Dynamic NFC tags product selector web page on st.com.
    Rgds
    BT
    David.Cheng
    Jul 23, 2019 5:10 AM UTC
    the idea is that mcu writes data to nfc, phone reads the data via NFC
    Brian TIDAL
    Rgds
    BT
    David.Cheng
    Jul 24, 2019 1:40 AM UTC
    thx, can dynamic tags store more than 64KB data?
    Brian TIDAL
    Jul 24, 2019 7:12 AM UTC
    ​Current products can store up to 64Kbits (8 Kbytes)
    Rgds
    BT
    #[ST25 NFC/RFID Tags and Readers]​
