CMath
Oct 23, 2018 12:53 PM UTC
Multiple tags ID in the GUI with the Inventroy button. Why is that?
Hello
I made some tests with the eval board. I use the ISO15693 standard to read some tags. I wanted to read up to 20 tags. Very often I get same tag ID twice in one reads cycle. Is this normal? I had the problem in the GUI over the inventory button.
Céline
    Ulysses HERNIOSUS
    Oct 1, 2020 3:00 PM UTC
    Hi Celine,
    I found this request in the basement - seems to have escaped our radar.
    In case this is still valid open, then you will need to share more details on your setup: Which board, which version of software, which functions did you used and also the kind of tags would be important.
    Regards, Ulysses
