mulitple NFC03A1 boards and SW integration with RPi4
wanted suggestions on SW integration to handle 2/3 NFC03A1 boards with RPi4
HW SPI connections seems to be ok
on the SW side, how to handle multiple spi.
Pls advise
Brian TIDAL
modify the various platform macros to dynamically handle 3 different configurations (mainly for IRQ_IN/IRQ_OUT and SPI) and just run 3 instances of the user space program (with a simple parameter on the command line for the configuration number).
Rgds
BT
venukrishAuthor
when we build will this not throw link errors ? can you clarify command line parameter differentiating the instances ?
question was how will 2 readers detect the tags, what if both the readers detect, how do we differentiate..
we would like to create a shared lib , as this will be called from a application or html page mostly
Brian TIDAL
can you describe in more details your application and how you plan to use the different readers?
Rgds
BT
