NFC/RFID Customer support
​Hello,
after deeper investigations, the issue could be from write to memory process included in the PC Software. Please find attached a new version of the PC software that can solve your issue. (Install attached file to get revision 2.3.1). This new version will be vailable on internet web site in few days.
If the issue is not corrected with the update, please check your binary file editor : it MUST display hexadecimal data, not binary data.
Best regards
It is very difficult to answer to your question regarding the little given informations.
Anyway, seeing the picture and 00110101 data in file, I suppose that the format of the binary file is not the good one. Binary file must contains BYTE informations and not BIT informations. I suggest to use a specific software to edit and create your comparison file (exemple Hex Editor).
I take this post to tell you a new software that can be used to manage CR95HF & ST25DV : ST25PC-NFC PC software
www.st.com/st25pc-nfc/
Best regards
John_zhang
0690X000006COUIQA4.bmpHi,
www.st.com/st25pc-nfc/ is not available, 404 Error Page
BR
John
Hi, this link should be good​
www.st.com/st25pc-nfc or www.st.com/st25pcnfc
Best regards
​Hello,
Best regards
sliu.5
sliu.5Author
thanks I success:face_with_tears_of_joy:
​Sure, ST25DV04K is 100% compatible with ST25DV64K.
ST25DV64K will support additional commands such as Extended Read commands and Extended Write commands to be able to access memory address > 0xFF (2 bytes address size).
sliu.5
sliu.5Author
OK thank you very much:smiling_face_with_heart_eyes: .
sliu.5
sliu.5Author
I want sak more a question,when I write file(the bin file ),the reader wrote a block (four byte)to tag every time ,how to designer reader for writing more block to tag every time.for example two block or more.
