steba
Jun 13, 2019 8:29 AM UTC
M24LR64E-R: I2C write to Configuration byte doesn't work
I am using ​M24LR64E-R. I am able to read system memory area and to read and write user memory via I2C, but If I try to write and update for example Configuration byte (address 2320, E2 = 1), the I2C write operation seems to be ok (no NACK received or error during write), but the Configuration byte is not updated. When I read back the location 2320 I get always the value F4h.
I don't think is a password protection problem because if I understand well the Configuration byte can be always read and write and anyway I have also tried to present the I2C password, but write to this register doesn't work.
Any idea and suggestion?
steba
stebaBest answer
Jun 13, 2019 9:42 AM UTC
​I solved. I was writing in a wrong way the address of the Configuration byte.
steba
stebaAuthorBest answer
