scott239955_stm1_stmicro_com
List of pre-certified modules based on ST25 chips
Is there a list someplace of pre-certified NFC modules which use ST25 chips?
Thanks,
Scott
    Brian TIDAL
    Brian TIDALBest answer
    Hi Scott,
    Unfortunately, such a list is currently not available.
    Regarding the ST25R95/CR95HF, the X-NUCLEO-NFC03A1 board based on this device is FCC certified (https://fccid.io/YCPNFC03A1/). The ST25R95/CR95HF is not NFC Forum certified
    I recommend reaching out to the local sales team, which can help you to find the right solution based on your requirements.
    Rgds
    BT
    Brian TIDAL
    Do you refer to NFC certification? If yes, you will find a list of NFC certified devices https://nfc-forum.org/products/certified-products/
    Rgds
    BT
    I'm referring to modules, not the ICs themselves, which have NFC and FCC certification. I wasn't aware of that list, so I appreciate knowing about it, but it doesn't give the IC on which each module is based. Does ST have a list of customers who have used the ST25 family in their certified end products? For instance, Nordic Semi has a list of third-party modules for each of their ICs, and it's really helpful. it would be great if ST had the same info.
    As I look through the list on the NFC Forum, it appears that the ST25R95 is not listed, but other ST ICs are listed. Is the ST25R95 not certified?
    Thanks,
    Scott
    Brian TIDAL
    Hi Scott,
    Rgds
    BT
    Hi Brian,
    Thank you for the confirmation. We'll sort out next steps.
    Best regards,
    Scott
