duncan
Sep 4, 2013 9:55 AM UTC
Issues with Programming CR95HF/M24LR in VB.net
Posted on September 04, 2013 at 11:55
Hi there, I am using a CR95HF board from a M24LR discovery kit to read data from a device. If I use the dual-interface EEPROM software from the ST website, select Reader Application and select M24LR64A, then click Read, or alternatively, 'show RF file transfer tools' and then save EEProm into a file' it does what I want, however I want to be able to include this functionality into my own software.
I have not programmed a hardware unit like this before, so am just getting used to it. I have constructed a small simple VB.net application based on the downloadable code examples, however there are some issues:
[code]
Public Declare Ansi Function CR95HFDll_Echo Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_Idn Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_Select Lib ''CR95HF.dll'' (ByVal mycmdstring As String, ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_SendReceive Lib ''CR95HF.dll'' (ByVal mycmdstring As String, ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_STCmd Lib ''CR95HF.dll'' (ByVal mycmdstring As String, ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_FieldOff Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_GetDLLrev Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_ResetSPI Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_SendIRQPulse Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDLL_getMCUrev Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    'added in Dll revision 0.4
    Public Declare Function CR95HFDLL_getInterfacePinState Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    'added in Dll revision 0.5
    Public Declare Function CR95HFDLL_USBconnect Lib ''CR95HF.dll'' () As Long
    Public Declare Function CR95HFDll_Polling_Reading Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Declare Function CR95HFDll_SendNSSPulse Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    'added in DLL revision 0.6
    Public Declare Function CR95HFDLL_USBhandlecheck Lib ''CR95HF.dll'' () As Long
    'added in DLL revision 0.9
    Public Declare Function CR95HFDLL_getHardwareVersion Lib ''CR95HF.dll'' (ByVal mystring As String) As Long
    Public Const CR95HF_STM32_error = &H1
    Public Const CR95HF_empty_argument_error = &H2
    Public Const CR95HF_cmd_parameter_error = &H3
    Public Const CR95HF_communication_error = &H4
    Public Const CR95HF_USB_communication_error = &H5
    Public Const CR95HF_ERRORCODE_DEFAULT = &HFE
    Public Const CR95HF_ERRORCODE_TIMEOUT = &HFD
[/code]
[code]
Dim lngStatus As Long = 5
        Dim lngStatus2 As Long = 6
        Dim strAnswer As New String('' ''c, 256)
        Dim strTagResponse As New String('' ''c, 256)
        lngStatus = CR95HFDLL_USBconnect()
        If (lngStatus = 0) Then
            lngStatus2 = CR95HFDll_Select(''010D'', strAnswer)
            CR95HFDll_SendReceive(''260100'', strTagResponse)
            MsgBox(''RFID Code is: '' & strTagResponse)
        Else
            MsgBox(''Warning : DEMO-CR95HF-A not connected'')
        End If
        Dim strAnswer2 As New String('' ''c, 256)
        lngStatus = CR95HFDll_STCmd(''010202010D'', strAnswer2)
[/code]
Firstly I do not know how to get the data from the code blocks as the EEPROM software does. I have looked through the manuals/documentation and just simply cannot figure it out. Also there are some issues with the return values. for the CR95HFDLL_USBconnect function it correctly returns 0 or 1, but for all the others, it just seems to return gibberish, and I do not know why. It could be to do with the string I am sending it, as vb.net cannot cope with the command ''As String*256''
any help would be appreciated!
#cr95hf #m24lr-discovery #cr95hf #vbnet #vbnet #vbnet #m24lr-discovery
duncan
duncanBest answer
Sep 23, 2013 3:34 PM UTC
Posted on September 23, 2013 at 17:34
this is just to let you know I have solved the problem. The issue is in the declaration for the DLLs and also the lngstatus numbers.  I would guess the dll has been compiled using a 32bit compiler, whereas the vb.net that I have installed uses a 64 bit compiler, so a 'long' is actually a 64bit number as far as my compiler is concerned. all the lead bits of the return are junk - whatever is in the memory at the time I guess. The problem is remedied by replacing long with uint32, so for example:
Public Declare Function CR95HFDll_SendReceive Lib ''CR95HF.dll'' (ByVal mycmdstring As String, ByVal mystring As String) As System.UInt32
Dim lngstatus As Uint32
lngstatus = CR95HFDll_SendReceive(command, strTagResponse)
returns the correct error codes.
Anais GALLIGANI
Sep 6, 2013 11:04 AM UTC
Posted on September 06, 2013 at 13:04
Please find here below a peace of code we could get. This can be usefull to set variables and environement on VB.NET.
DLL FUNCTIONS DECLARATION :
declaration
Public
Declare
Function
Lib
''CR95HF.dll''
As
Integer
Public
Declare
Function
CR95HFDll_Echo
Lib
''CR95HF.dll''
ByVal
mystring
As
String
As
Integer
Public
Declare
Function
CR95HFDLL_getMCUrev
Lib
''CR95HF.dll''
ByVal
mystring
As
String
As
Integer
Public
Declare
Function
CR95HFDll_Select
Lib
''CR95HF.dll''
ByVal
mycmdstring
As
String
ByVal
mystring
As
String
As
Integer
Public
Declare
Function
Lib
''CR95HF.dll''
ByVal
mycmdstring
As
String
ByVal
mystring
As
String
As
Integer
Public
Declare
Function
CR95HFDll_STCmd
Lib
''CR95HF.dll''
ByVal
mycmdstring
As
String
ByVal
mystring
As
String
As
Long
INVENTORY COMMAND - FUNCTION EXAMPLE :
Dim
strTagReponseCons0 =
New
String
CChar
), 256)
Dim
lngStatusCons0
As
Long
lngStatusCons0 = CR95HFDll_SendReceive(“260100�?, strTagReponseCons0)
I think that the declaration of Tag answer need to be changed in “
New
String
CChar
), 256)
Might you tell us if this solve your issue?
Thanks a lot,
ST NFC/RFID dynamic tag support
duncan
duncanAuthor
Sep 9, 2013 10:23 AM UTC
Posted on September 09, 2013 at 12:23
Thanks for the reply. I have tried this and it is putting the correct thing in the return string, however the 'long' status is still nonsense. For the first command, CR95HFDLL_USBconnect() it returns 0, however for subsequent commands it returns numbers like 65497649968578560, meaning I cannot use it as a status check.
Also I was hoping you could let me know of a command that allows me to access the on board memory. As I mentioned before, If I use the dual-interface EEPROM software from the ST website, select Reader Application and select M24LR64A, then click Read, or alternatively, 'show RF file transfer tools' and then save EEProm into a file' it does what I want, however I want to be able to include this functionality into my own software.
Thanks for the help!
Duncan
duncan
duncanAuthor
Sep 10, 2013 9:48 AM UTC
Posted on September 10, 2013 at 11:48
I've managed to get it to do most of what I want, however the return codes are still giving values like 340187712222920704
Anais GALLIGANI
Sep 11, 2013 8:14 AM UTC
Posted on September 11, 2013 at 10:14
Hello Hill,
As w
e don’t have VB.NET application based here, it is not easy to help deeper on programmation syntax.
How have you solve the previous issue?
duncan
duncanAuthor
Sep 23, 2013 2:27 PM UTC
Posted on September 23, 2013 at 16:27
I did as you suggested - the code is returning meaningful values in the string, but as I mentioned, the dll is still not returning anything sensible in the lngstatus values.
duncan
duncanAuthorBest answer
