GErma.1
Is the ST25DV64K tag compatible with a ISO14443-A reader?
Hi
I would like to know if the ST25DV64K tag is going operate with a regular SO14443-A reader? I have already tested the tag against a Samsung S10 phone running the ST's app and is working perfectly.
Best Regards
Gilberto
    Berenice BENVEGUDA
    ​Hello Gilberto,
    If you need and I2C interface and ISO144443-A product you have the M24SR64K product available at the link below :
    https://www.st.com/content/st_com/en/products/nfc/st25-nfc-rfid-tags-readers/st25-dynamic-nfc-tags/m24sr-series-dynamic-nfc-tags/m24sr64-y.html
    the Datasheet is available here :
    https://www.st.com/resource/en/datasheet/m24sr64-y.pdf
    Best Regards,
    BB
    Berenice BENVEGUDA
    ​Hello Gilberto,
    The ST25DV64K tag is going to operate well with a regular ISO14443-A reader, with respect to initialization phase ( Anticollision, RATS, Select Application, Select File commands …)
    Best Regards,
    BB
    Berenice BENVEGUDA
    Hello Gilberto,
    sorry I read too fast your question
    ST25DV64K is not compatible with an ISO14443-A reader​ because it is ISO15693 compliant.
    If you need an ISO14443-A compatible tag you have ST25TA64K in ST portfolio.
    Best Regards,
    BB
    GErma.1
    GErma.1Author
    Hi Can you provide me a link to ST25TA documentation? I think the TA model does not have a I2C interface. Best Regards Gilberto Em seg, 26 de out de 2020 11:23, ST Community escreveu:
    Berenice BENVEGUDA
    ​Hello Gilberto,
    Best Regards,
    BB
