Massimo Ponte
is it possible to connect more than one RFDemo Board and use them asynchronously ?
Posted on November 03, 2017 at 15:30
Hello, I'm using the RF Transceiver Demonstration Board, I connected it via USB, I successed in writing labview code that  read/write messages via NFC to a device.
My question is: is it possible to connect more than one Demo Board and use them asynchronously ? I need to read/write NFC messages at least to two devices at the same time.
Thank you
Regards.
Massimo Ponte
#m24lr-discovery
    NFC/RFID Customer support
    Posted on December 15, 2017 at 17:02
    Hi Massimo,
    If your question is about CR95HF-DEMO kit (embedded in the M24LR-DISCOVERY kit), it is not possible to use 2 readers via USB ports.
    Best regards
    Hi Massimo,
    Best regards
