AGarc.8
IOS NFC-TAP doesn't read FTM buffer
Hi everyone, I would like use FTM feature of ST25DV.
I develop the code to write EEPROM and buffer of FTM, I can read this buffer with developed Kit and ST25PC-NFC software.
But I can't use APP for IOS NFC-TAP because it doesn't read FTM buffer. why?
victor laraison
victor laraisonBest answer
Hi AGarc,
I'm in charge of developing the iOS NFC Tap for ST25 products.
Please, could you detail more the use case ? Then providing version of iOS NFC Tap you're using.
In the iOS NFC Tap, when the ST25DV tag is detected, there is a menu "ST25DV Fast Transfert Mode" for playing with different use cases with FTM (Picture transfert, Firmware upload, ...)
Have you changed something in FTM protocol ?
Thx and br
victor laraison
Hi AGarc,
Thx and br
Hi Laraison
 I got the same problem, could you help me with this?
and i posted and detailed my problem already in this website.
thank you very much
my email: ivan@caseguider.com
Ivan
Hi Agarc
 Have you already solved you problems?
Ivan T
