MBell.4
Importing the iOS NFC Tap SDK
How can i Import the iOS NFC Tap SDKs to my swift app ? which Libs are relevant ?
    victor laraison
    victor laraisonBest answer
    hi Mbell,
    iOS NFC Tap SDK is not provided as a "lib" into the application. You have to add and compile every files located into the folder st25sdklib from the iOS NFC Tap app.
    Then , update your bridging header file accordingly and Header Search Path into your target build setting.
    The most important external library to be used is the J2OBC. I attached here a document on how to use it.
    Hope it helps.
    Thx and br,
    victor laraison
    hi Mbell,
    Hope it helps.
    Thx and br,
