michael.gaechter
I am using an ST25DV64 with an Android 8. I can read and write NDEF messages using the ST25 tap app only. If I write an NDEF message using any other app the operation fails (e.g. NFC tools from the android store). Can you tell me how to set CC File?
    JL. Lebon
    JL. LebonBest answer
    ​Hello,
    There is two way of reading NDEF messages with Android: native reading (reading without application) and reading with dedicated application.
    You have to be aware that android version < 9.0 does not support native reading with tags with memory larger that 8kbits. Android >= 9.0 supports native reading of tag with any memory size.
    With dedicted application, there is not this limit, whatever android version. That's why you are able to read/write the ndef message with the ST25Tapp app.
    It should work also with other applications, assuming they write or understand the correct CCFile.
    For CC File formating on ST25DV, I recommand you to read the following aplication note (AN4911), where everything is explained: https://www.st.com/resource/en/application_note/dm00328901-ndef-management-with-st25dvxxx-and-st25tvxxx-products-stmicroelectronics.pdf
    Best regards.
    JL. Lebon
    ​Hello,
    Best regards.
