IPire
How to write on dynamic registers using ST25 Java SDK and android.
I'm starting to develop an application to read and write on NFC tag's mem. But I want to disable the GPIO pulse on write in some cases, to do it i have to write on tag's registers. I do not found on SDK docs how to do it. Does anyone know how can I do this? and Where I can find support or code examples to do this applications?
Damien G.Best answer
you can find source code for the ST25 NFC Tap Android application based on the st25sdk library at this page:
https://www.st.com/content/st_com/en/products/embedded-software/st25-nfc-rfid-software/stsw-st25001.html
At the bottom of the page, you will find 2 links:
  • STSW-ST25001 for the apk file
  • STSW-ST25002 for the source code
For your particular need, from the source code package, locate file ST25AndroidApp\app\src\main\java\com\st\st25nfc\generic\RegistersActivity.java
Regards,
Damien
Regards,
Damien
