Dosan
Dec 14, 2021 12:02 PM UTC
How to use DLL CR95HF.dll on VB.NET?
Hi eveyone,
I need to use the CR95HF.dll library on a VB.NET application but when i try insert on the project i get an error.
I think this library is VB compatible only but i dont sure about this.
Maybe anyone know how to port this library to be used on VB.NET or how could i use on NET platform.
Thanks.
Regards,
    NFC/RFID Customer support
    Dec 16, 2021 1:34 PM UTC
    another suggestion :
    Using Visual Studio 2015, the format of DLL answer need to be formatted before to be used :
    1. Dim strAnswer = New String(CChar(""), 256)
    You must use this formatted variable in all functions to get DLL answer .
    another suggestion : it is possible that Get DLL revision doesn't return "0" when you get DLL revision number.
    You can can see the exact value with debug mode.
    Hope this will help you,
    Best regards,
    NFC Customer support
    Dosan
    DosanAuthor
    Apr 1, 2022 10:06 AM UTC
    Thanks for your reply.
    Regards,
