How to use DLL CR95HF.dll on c#?
Hello Everyone,
I'm developing a WPF(.NET Framework) application in which i'm using the CR95HF.dll also I'm using the CR95HF Demo Board to read some ICs like M24LRxxE and ST25DVxxK
I've made some readings using VB.NET since all the information I found is for VB. and it works fine for me because I've read some tags.
Unfortunately my final application is based on C#, so my question is if there are some code samples or some docs that give instructions on how to use C# to make the connections.
or how to declare those kind of functions to be able to work using C#
Public Declare Function CR95HFDLL_USBconnect Lib "CR95HF.dll" () As Long
Public Declare Function CR95HFDll_Idn Lib "CR95HF.dll" (ByVal mystring As String) As Long
Public Declare Function CR95HFDll_SendReceive Lib "CR95HF.dll" (ByVal mycmdstring As String, ByVal mystring As String) As Long
Public Declare Function CR95HFDll_STCmd Lib "CR95HF.dll" (ByVal mycmdstring As String, ByVal mystring As String) As Long
Brian TIDAL
Brian TIDALBest answer
as far as I know there is no sample code for C# with the CR95HF DLL. Anyway, you may find answers on how to call functions from an unmanaged DLL in the following links:
Rgds
BT
Brian TIDAL
Rgds
BT
